Follow these steps to connect your Twitter Organic data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, and data warehouses, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the Twitter Organic connector to fetch organic tweet data, you must have a completed Twitter profile and an active Twitter Ads account connected to it. Follow these steps to create a Twitter Ads account.
- Profile info: Get Twitter profile-level metrics.
- Tweet engagement: Measure the organic performance of your tweets.
- Under Data source, select Twitter Organic.
- Log in to the Twitter account you want to fetch data from.
- Click Authorize app to allow the Supermetrics app to access your profile data.
- Navigate to Report configuration and select a query type.
- To start using Twitter Organic in Looker Studio, click this link.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Twitter Organic requires authorization to connect to data").
- Click +Create transfer.
- Select the Twitter Organic data source.
- Accept the agreement.
- Click Authorize with Twitter Organic.
- Click Submit.
- Click Save.
- Click Create new.
- Click Create transfer.
- Click Select data source.
- Hover over the Twitter Organic data source, and click Connect.
