Follow these steps to add your Microsoft Advertising data to your Supermetrics reports.
To connect Supermetrics to Microsoft Advertising, you need:
- A Microsoft user account with at least Advertiser Campaign Manager access to an ad account. Learn how to grant access to Microsoft Advertising account.
- Multi-factor authentication enabled for the Microsoft user account — this is a requirement for access to Microsoft Advertising via its API. See Microsoft's account security information for more details.
- Under Data source, select Microsoft Advertising.
- Enter your Microsoft email address and click Next.
- Enter your Microsoft password and click Sign in.
- Navigate to Microsoft Advertising and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Microsoft Advertising requires authorization to connect to data").
