Getting your marketing reporting data into monday.com is easy and fast. Follow the steps below.
You need a monday.com account to use the Supermetrics app on monday.com.
You also need appropriate permissions to fetch data from the data sources. Learn more about data source permission requirements.
Install the Supermetrics app
- Go to Supermetrics on the monday.com apps marketplace.
- Click Add to your account.
- Select the workspaces to install the app for.
- Click Install.
- Select the Campaign reporting workspace template, and click Next.
- Select a workspace and click Add.
- Review the app permissions and click Authorize.
Connect to the first data source
- Select the first data source to connect to.
- Click Connect.
- Enter your credentials for the data source.
- Select the ad accounts you want to include, and click Next.
- Click Go to dashboard.
