This guide will walk you through how to authenticate or reauthenticate Simplesat with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Simplesat, you need:
- Simplesat uses an account/API key for authentication.
- Read Simplesat’s documentation to learn how to find your account/API key.
For Excel users
- Click Create query.
- Under Data source, select Simplesat.
- Enter your credentials and click Log in.
- Click Allow.
- Under Select accounts, select the accounts.
- Navigate to Simplesat and click Try.
- Click Authorize.
- Click Authorize.
- Select your accounts.
- Click Connection in the top right-hand side.
- Click the edit icon next to Simplesat in the Data Studio sidebar.
- Scroll down to Parameters.
Before you can authenticate Simplesat in Excel, you need to install the Supermetrics add-in.
- BigQuery
- Data warehouses and cloud storage (Amazon S, Google Cloud Storage, Snowflake, Azure Storage, or Azure Synapse)
- The Supermetrics API
Reauthenticate Simplesat
