Semrush Projects connection guide
Follow this guide to connect your Semrush Projects data to the reports you create with Supermetrics.
To connect Supermetrics to Semrush Projects, you need an API account, an API key, and a Semrush subscription for API request units. Learn more about Semrush accounts and API request units.
For Excel users
Google Sheets Data StudioExcel
  3. Click Create new query.
  4. Under Data source, select Semrush Projects.
  5. Enter your API key and click Start.
  6. Select a project to include in your reports.
  7. Navigate to "Report configuration", and choose your query type.
