Facebook Ads connection guide
Follow these steps to connect your Facebook Ads data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Your Facebook Ads accounts need different types of access to pull different types of data. Make sure your accounts have the right permissions before going ahead.
Your Facebook account needs:
  • Employee access with the View performance option enabled, or Ad account analyst access to an ad account.
  • If you're using the new Pages experience, your account needs partial access to the linked Facebook account.
For access to Lead data, your account needs Lead manager or Page admin access.
  3. Click Create query.
  4. Under Data source, select Facebook Ads.
  6. Click Start.
  7. Either log in with a new Facebook account, or click Continue as to go ahead with the account you're already logged in to.
  8. Select the Businesses and Pages you want to include in your reporting.
  9. Review the permissions, and click Save.
  10. Click Got it.
  11. In the Supermetrics sidebar, select the accounts you'd like to include in your reporting.
  2. Navigate to Facebook Ads and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Facebook Ads requires authorization to connect to data").
  7. Click Start.
  8. Either log in with a new Facebook account, or click Continue as to go ahead with the account you're already logged in to.
  9. Select the Businesses and Pages you want to include in your reporting.
  10. Review the permissions, and click Save.
  11. Click Got it and click Done.
  12. Select the accounts you'd like to include in your reporting.
  13. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  14. In the pane's top right, click Connect.
  15. Click Create report.
  16. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Facebook Ads.
  5. Click Start.
  6. Either log in with a new Facebook account, or click Continue as to go ahead with the account you're already logged in to.
  7. Select the Businesses and Pages you want to include in your reporting.
  8. Review the permissions, and click Save.
  9. Click Got it.
  10. In the Supermetrics sidebar, select the accounts you'd like to include in your reporting.
Data warehouse
  3. Click + Create transfer.
  4. Select the Facebook Ads data source.
  7. Accept the agreement.
  8. Click Authorize with Facebook Ads.
  9. Click Start.
  10. Either log in with a new Facebook account, or click Continue as to go ahead with the account you're already logged in to.
  11. Select the Businesses and Pages you want to include in your reporting.
  12. Review the permissions, and click Save.
  13. Click Got it.
  14. Select the accounts you'd like to include in your reporting and define the transfer settings.
  15. Click Submit.
  16. Click Save.
  2. In the sidebar, go to StorageTransfers.
  3. Click New transfer. If you haven't created any transfers yet, click Schedule first transfer
  4. Select the Facebook Ads data source, and click OK.
  7. Click Start.
  11. Click Got it.
  12. In the transfer setup view, select the accounts you'd like to include in your reporting and define the transfer settings.
  13. Click Create transfer.
Power BI
  2. In the sidebar, go to DestinationsPower BI.
  3. Click Create or edit queries.
  4. Click Select a data source.
  5. Select the Facebook Ads data source.
  6. Click Start.
  10. Click Got it.
  11. In the query setup view, select the accounts you'd like to include in your reporting and fill in the query details.
  12. Click Run query to test your query.
The Supermetrics API
  2. In the sidebar, click API.
  4. Click Select data source.
  6. Click Start.
  10. Click Got it.
  11. In the transfer setup view, select the accounts you'd like to include in your reporting and fill in the query details. See detailed instructions on how to set up a Supermetrics API query in Query Manager.
  12. Click Run to test your query.
Supermetrics Hub
  2. In the sidebar, click Data sources.
  4. Hover over the Facebook Ads data source, and click Connect.
  5. Click Start.
  9. Click Got it.
