Follow these steps to connect your Capterra PPC data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Capterra PPC, you need API access and an API key enabled by the Capterra account manager.
- Under Data source, select Capterra PPC.
- Enter your account name and API key.
- Navigate to Capterra PPC and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Capterra PPC requires authorization to connect to data").
- Click Done.
- Select a Supermetrics team and a query type.
- Click Next.
- Click Create report again.
- Click + Create transfer.
- Select the Capterra PPC data source.
- Accept the agreement.
- Click Authorize with Capterra PPC.
- Click Submit.
- Click Save.
- Select the Capterra PPC data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Capterra PPC data source, and click Connect.
