This guide will walk you through how to authenticate or reauthenticate Clockify in Supermetrics for Google Sheets, Data Studio, and Excel.
To connect Supermetrics to Clockify, you need:
- An Admin user role level. Learn more about Clockify permissions.
- An API key. Learn how to generate this token in Clockify.
With Clockify, you can:
- Track time spent (duration) for different tasks by time entries.
- Track cost/billable amount for different projects.
- Fetch data by time, by user, by client, or by project.
- Fetch billable and non-billable hours separately, and see what is the effective billing rate across your employees and projects.
- See how actual hours and costs compare to budgeted costs and time estimates.
- Under Data source, select Clockify.
- Enter your Account name and API key and click Start.
- Select your accounts.
When you're ready, learn how to create your first Supermetrics query with Clockify.
- Navigate to Clockify and click Try.
- Click Authorize.
- Click Authorize.
- Scroll down to Parameters.
Connections
- Choose if this connection should be shared or private.
- BigQuery
- The Supermetrics API
Reauthenticate
