This guide will walk you through how to authenticate or reauthenticate Facebook Ads for Supermetrics in Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Facebook Ads, you need:
- Employee access with the View performance option enabled in an ad account, or Ad account analyst access to an ad account.
- For Lead data access, your account must either be a Lead manager or a Page admin.
- Agencies must have Page admin access.
- If you’re using the new Pages experience, you need partial access to the linked Facebook account.
Visit Facebook’s help center to learn more about adding permissions and controlling who can access your leads.
- Under Data source, select Facebook Ads.
- A Facebook login page will open. Enter your credentials, and click Log in. (If you're already logged in to Facebook in the browser, click Continue with Facebook.)
- Click Continue as to authenticate with that user account, or log in with another account.
- You'll be prompted to choose Pages. You can skip this step as Facebook Ads is for accounts only.
- Click Done.
- Click OK.
- Select the accounts you want to add to your reporting.
- Navigate to the data source and click Try.
- Click Authorize.
- Click Authorize.
- A Facebook login page will open. Enter your credentials, and click Log in. (If you're already logged in to Facebook, click Continue with Facebook.)
- You will be prompted to choose Pages. You can skip this step as Facebook Ads is for accounts only.
- Click Done.
- Click OK.
- Scroll down to Parameters.
Connections
- A Facebook login page will open. Enter your credentials and click Log in. (If you're already logged in to Facebook, click Continue with Facebook.)
- Click Done.
- Click OK.
- Select the accounts you'd like to add to your reporting.
- BigQuery
- The Supermetrics API
Reauthenticate
- If you're missing a Facebook account, follow these steps.
- For error: Two Factor Authentication Required, follow these steps.
