Follow these steps to connect your Facebook Billing Data data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Facebook Billing Data, you need the Finance Editor access level. Learn more about Facebook Business Manager permissions.
You also need to have monthly invoicing enabled for your Facebook Business Manager account to get its invoice data. Supermetrics can't pull data on transactions that aren't part of a monthly billing cycle. Learn more about monthly invoicing.
You can query your lists of invoices and invoicing amounts, as well as rich metadata, campaign, and performance data for each invoice.
- Under Data source, select Facebook Billing Data.
- Either log in with a new Facebook account, or click Continue as to go ahead with the account you're already logged in to.
- Select the Businesses you want to include in your reporting.
- Review the permissions, and click Save.
- Click Got it.
- In the Supermetrics sidebar, select the accounts you'd like to include in your reporting.
- Navigate to Facebook Billing Data and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Facebook Billing Data requires authorization to connect to data").
- Click Got it and click Done.
- Select the accounts you'd like to include in your reporting and a query type.
- Click Next.
- Click Create report again.
- Click Got it.
- Click + Create transfer.
- Select the Facebook Billing Data data source.
- Accept the agreement.
- Click Authorize with Facebook Billing Data.
- Click Got it.
- Click Submit.
- Click Save.
- Select the Facebook Billing Data data source, and click OK.
- Click Got it.
- Click Create transfer.
- Click Select a data source.
- Click Got it.
- In the query setup view, select the accounts to include in your reporting and fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Click Got it.
- In the query setup view, select the accounts to include in your reporting and fill in the query details. See detailed instructions on how to set up a Supermetrics API query in Query Manager.
- Hover over the Facebook Billing Data data source, and click Connect.
- Click Got it.
