Use this guide to learn how to connect your Capterra PPC or Capterra Reviews data to Supermetrics. Both of these data sources follow the same steps, with a few minor variations.
If you need to connect either of these data sources to one of our data warehouse or cloud storage destinations, explore our prerequisite and filling guides.
To connect Supermetrics to Capterra PPC, you need:
- API access and an API key enabled by the Capterra account manager.
To connect Supermetrics to Capterra Reviews, you need:
- A Capterra product identifier for search. This identifier can be taken from the URL of the product page in Capterra.
- Under Data source, select Capterra PPC or Capterra Reviews.
- To connect Capterra PPC, enter your account name and API key, and click Start.
- To connect Capterra Reviews, click Start, and then navigate to Report configuration. Enter your software ID in the field of the same name.
- Navigate to Capterra PPC or Capterra Reviews and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Capterra PPC, or Capterra Reviews, requires authorization to connect to data").
