This guide will walk you through how to authenticate or reauthenticate Capterra PPC and Capterra Reviews with Supermetrics in Google Sheets, Data Studio, and Excel.
To connect Supermetrics to Capterra PPC, you need:
- API access and an API key enabled by the Capterra account manager.
To connect Supermetrics to Capterra Reviews, you need:
- A Capterra product identifier for search. This identifier can be taken from the URL of the product page in Capterra.
Features
With Capterra PPC, you can:
- Report all the basic metrics for your advertising and promotions: cost, clicks, conversions, average position, CPC, and CPA/CPL.
Fetch data by vendor, product, country, channel, or by time.
Report data from three different platforms: Capterra, GetApp, and Software Advice.
With Capterra Reviews, you can:
- Fetch data from 250 most recent reviews for any product.
- Open a new Google Sheets file
- Under Data source, select Capterra PPC or Capterra Reviews.
- For Capterra PPC:
Enter your Account name and API key, and click Start.
Navigate to Report configuration.
For Capterra Reviews:
Under Software ID, insert the software ID.
- Open the Supermetrics data source gallery
- Navigate to the data source and click Try.
- Click Authorize.
- Click Authorize.
- For Capterra PPC:
Under Software ID, insert the software ID. - Click Connect on the top right-hand side.
- Scroll down to Parameters.
Connections
- Click Data → Show Supermetrics
- Under Data source, select the data source.
- For Capterra PPC:
Choose if this connection should be shared or private.
