Creating a destination: Prerequisites for GCS Bucket
Before you create a destination to start transferring data to your Google Cloud Storage (GCS) Bucket, see these prerequisites.
Once you've made sure all prerequisites are met, see our guide for How to configure a data destination.
Prerequisites for creating a destination
1. You need to have an existing GCS Bucket.
2. You need to have a Service Account that has at least the Storage Object Creator role, as well as either Storage Admin role or a Custom Role with storage.buckets.get permission for the bucket you want to use for your transfers.
You or your GCP Admins can create a Service Account in the Google Cloud Platform, under IAM & Admin → Service Accounts at console.cloud.google.com/iam-admin/serviceaccounts. You will also need to create a JSON key for that Service account. The entire JSON key file content is needed to create the destination at team.supermetrics.com – it should look similar to this:
  "type": "service_account",
  "project_id": "<YOUR_GCP_PROJECT_ID>",
  "private_key_id": "12345ABCDummyKey",
  "private_key": "-----BEGIN PRIVATE KEY-----\12345ABCDummyKey\n-----END PRIVATE KEY-----\n",
  "client_email": "<NAME_OF_SERVICE_ACCOUNT>@<YOUR_GCP_PROJECT_ID>.iam.gserviceaccount.com",
  "client_id": "12345ABCDummyClientID",
  "auth_uri": "https://accounts.google.com/o/oauth2/auth",
  "token_uri": "https://oauth2.googleapis.com/token",
  "auth_provider_x509_cert_url": "https://www.googleapis.com/oauth2/v1/certs",
  "client_x509_cert_url": "https://www.googleapis.com/robot/v1/metadata/x509/<NAME_OF_SERVICE_ACCOUNT>%40<YOUR_GCP_PROJECT_ID>.iam.gserviceaccount.com"
Additionally, you can define the role for the Service Account in the Permissions tab for a specific bucket:
3. Sufficient permissions
  • You or your GCP Admins can either assign the role Storage Object Admin to the Service Account or create a custom role with permissions “storage.objects.create”, “storage.objects.delete”, “storage.objects.get” and “storage.objects.list”. See instructions in Google Cloud IAM Documentation: Creating and managing custom roles.
4. IP whitelisting is needed if your GCP projects only allows access from “selected networks”.
  • You or your GCP Admins can add the following Supermetrics IP addresses to your GCP setup, if your organization requires IP whitelisting:
    - 54.75.55.54
    - 54.75.80.21
    - 54.247.165.52
    - 23.20.234.176
    - NOTE: Do not forget to add your own IP address to avoid getting “locked out”.
How to configure a data destination »
Creating a destination: Filling instructions for GCS Bucket »
