Salesforce connection guide
This guide contains all permissions and requirements for connecting your Salesforce data to Supermetrics.
Note
It's important to contact your Salesforce system administrator for help before you begin this process. Salesforce instances often have custom security settings that need careful attention.
To connect Supermetrics to Salesforce, you need read access to objects and fields. Learn more about Salesforce permissions.
Supermetrics supports the following objects and the fields under them: accounts, campaigns, contacts, leads, opportunities, and tasks.
When connecting to Salesforce, you need to log in to Salesforce and select the accounts to use.
  1. Select the Salesforce data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Enter your Salesforce email address and password, and click Log in.
  5. In your data destination, select the accounts you'd like to include in your reporting.
You can also connect to Salesforce from these destinations:
