This guide will walk you through how to authenticate or reauthenticate Microsoft Advertising in Supermetrics with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Microsoft Advertising, you need:
- A Microsoft user account with at least Advertiser Campaign Manager access to an ad account. Learn how to grant access to Microsoft Advertising account.
- Multi-factor authentication enabled for the Microsoft user account — this is a requirement for access to Microsoft Advertising via its API. See Microsoft's account security information for more details.
- Under Data source, select the data source.
- Enter your Microsoft email address and click Next.
- Enter your Microsoft password and click Sign in.
- Navigate to Microsoft Advertising and click Try.
- Click Authorize.
- Click Authorize.
- Scroll down to Parameters.
Connections
- Under Data source, select Microsoft Advertising.
- Under Select accounts, select the accounts.
- BigQuery
- The Supermetrics API
