This guide will walk you through how to authenticate or reauthenticate Mailchimp in Supermetrics for Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Mailchimp, you need a Mailchimp user account with an Owner or Admin user role level. See Mailchimp’s documentation for instructions on how to grant access for a user account.
Multi-account login
It's not possible to log into Mailchimp in Supermetrics with multiple accounts.
If you've authenticated with Mailchimp credentials that have access to multiple Mailchimp accounts, there's a risk that future refreshes will show unpredictable combinations of data from any of the accounts that the original account has access to. Learn more about pulling data from multiple Mailchimp accounts.
- Automations: Returns automations. Does not include customer journeys.
- Automation emails: Returns individual emails in a classic automation workflow.
- Lists: Returns Mailchimp lists, also known as audience.
- Campaigns: Returns campaigns from your MailChimp account.
- List activity: Returns daily, aggregated activity stats for your list. For example, view unsubscribes, signups, total emails sent, opens, clicks, and more, for up to 180 days.
- List growth history: Returns a summary of the month-by-month growth activity for a specific list.
- List locations: Returns locations (countries) of subscriber lists.
- List members: Returns members of a specific Mailchimp list, including currently subscribed, unsubscribed, and bounced members.
Incompatible fields
You might encounter this error when pulling data from Mailchimp in Supermetrics with either Google Sheets or Data Studio:
- Incompatible fields: IllegalDimensionMetricCombinationException
To fix this error, follow these steps.
- Under Data source, select the data source.
- Select an account.
- Click Allow.
- Under Select campaigns/lists, select your campaign/lists.
- Navigate to Mailchimp and click Try.
- Click Authorize.
- Click Authorize.
- Enter your credentials and click Log in.
- Click Allow.
- Select the campaigns you'd like to include in your reporting.
- Select a query type.
- Scroll down to Parameters.
Connections
- Under Data source, select Mailchimp.
- Click Allow.
- Select the campaigns and lists you'd like to include in your reporting.
- BigQuery
- The Supermetrics API
