Follow these steps to connect your LinkedIn Ads data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect to LinkedIn Ads, you need:
- A LinkedIn account with at least Viewer access to an ad account. Learn how to grant access to LinkedIn accounts.
- Admin access to the Company Page is required for creative-level (ad content and metadata) granularity.
- Click Create query.
- Under Data source, select LinkedIn Ads.
- Enter your credentials and click Sign in.
- Navigate to LinkedIn Ads and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "LinkedIn Ads requires authorization to connect to data").
- Click + Create transfer.
- Select the LinkedIn Ads data source.
- Accept the agreement.
- Click Authorize with LinkedIn Ads.
- Click Submit.
- Click Save.
- Select the LinkedIn Ads data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the LinkedIn Ads data source, and click Connect.
- LinkedIn Ads report building guide
- LinkedIn Ads: Permissions troubleshooting
- What to do if accounts, custom fields, or segments are missing from your report
- How to reauthenticate a data source in Looker Studio, Google Sheets, or Excel
- How to reauthenticate a data source in data warehouse, API, or cloud storage platform
- How to manage data source connections on the Supermetrics Hub
