This guide will walk you through how to authenticate or reauthenticate Criteo for Supermetrics in Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Criteo, you need:
- An API user with a client ID and client secret
- An app with at least Read access for all elements of the Marketing API. To create these credentials, follow these instructions.
- If you're logged with an old Criteo app, you'll need to log out of Criteo and then log back again. To install a new app, follow these steps.
- Under Data source, select Criteo.
- Enter your Criteo client ID and client secret, and click Start.
- Select your accounts.
- Navigate to the data source and click Try.
- Click Authorize. If you're authenticating the data source for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
When you're ready, learn how to create your first Supermetrics query with Criteo.
- Scroll down to Parameters.
Connections
- Choose if this connection should be shared or private.
- BigQuery
- The Supermetrics API
