Adform connection guide
Follow these steps to connect your Adform data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect to Adform, you need:
  3. Click Create query.
  4. Under Data source, select Adform.
  6. Click Start.
  7. Log in to your Adform account.
  8. Click Allow.
  2. Navigate to Adform and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Adform requires authorization to connect to data").
  7. Click Start.
  8. Log in to your Adform account.
  9. Click Allow.
  10. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Adform.
  5. Click Start.
  6. Log in to your Adform account.
  7. Click Allow.
Data warehouse
  3. Click + Create transfer.
  4. Select the Adform data source.
  7. Accept the agreement.
  8. Click Authorize with Adform.
  9. Click Start.
  10. Log in to your Adform account.
  11. Click Allow.
  13. Click Submit.
  14. Click Save.
  3. Click Create new.
  4. Select the Adform data source, and click OK.
  7. Click Start.
  9. Click Allow.
  11. Click Create transfer.
Power BI
  3. Click Select data source.
  5. Click Start.
  7. Click Allow.
  8. Fill in the query details.
The Supermetrics API
  4. Click Select data source.
  5. Select the Adform data source.
  6. Click Start.
  8. Click Allow.
Supermetrics Hub
  4. Hover over the Adform data source, and click Connect.
  5. Click Start.
  7. Click Allow.
