Follow these steps to connect your Piano Analytics (AT Internet) data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the Piano Analytics (AT Internet) connector, you must get your site ID as well as an access key and secret key.
- Log in to Piano Analytics (AT Internet).
- Open the Data Query feature.
- Select the “Site ID” as the row and “Visits” as the column.
- Click the arrow on the right side to launch the query.
- Your site ID should now be visible in the table. Copy and save this number.
- If you have multiple sites that you want to report for, copy and save each one.
- In "Piano Analytics (AT Internet)", go to your profile page.
- Select the API Keys tab.
- Select Create a new API Key.
- Give any name for this key, for example, “Supermetrics”.
- Click Create a new API Key.
- Copy the access key and secret key to a safe place.
- Click OK.
- Performance report: Analytics data for your website, including metrics for acquisition and on-site behavior.
- Under Data source, select Piano Analytics (AT Internet).
- Enter the site ID that you want to report for.
You can enter one site as “12345”, or multiple sites separated by commas: “12345,56342,23444”.
- Enter your access key and secret key.
- Navigate to Piano Analytics (AT Internet) and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Piano Analytics (AT Internet) requires authorization to connect to data").
- Select the query type.
- Click Next.
- Under Data Source, select Piano Analytics (AT Internet).
- Click + Create transfer.
- Select the Piano Analytics (AT Internet) data source.
- Accept the agreement.
- Click Authorize with Piano Analytics (AT Internet).
- Click Submit.
- Click Save.
- Select the Piano Analytics (AT Internet) data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Piano Analytics (AT Internet) data source, and click Connect.
