Follow these steps to connect your Rakuten Advertising data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Supermetrics fetches performance data for affiliate campaign advertisers through Rakuten Advertising. It doesn't currently support the platform's publisher side.
To connect to Rakuten Advertising, you need to create a report, and then get your report key and API token. Follow the steps below to meet these prerequisites.
- Log in to Rakuten Advertising.
- Navigate to Reports, and then Reporting.
- Select an existing report, or build a new one. Select every column that you want to use in Supermetrics. You can alter the time range and other report settings at any time in Supermetrics itself.
- Save the report.
- Open the report you want to use in Supermetrics.
- Click the dropdown next to View report.
- Click Get API.
- You'll see your API URL. From it, pull:
- Report key: Copy the string that follows /reports/ in the URL. It should match the name you gave your report.
- API token: Copy the string that follows &token= in the URL.
- Here's an example: //ran-reporting.rakutenmarketing.com/en/reports/[REPORT-KEY]/filters?date_range=this-month&include_summary=Y&tz=GMT&date_type=transaction&token=[API-TOKEN]
- Save your report key and API token securely.
- Click Create query.
- Under Data source, select Rakuten Advertising.
- Enter your report key and API token.
- Navigate to Rakuten Advertising and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Rakuten Advertising requires authorization to connect to data").
- Click + Create transfer.
- Select the Rakuten Advertising data source.
- Accept the agreement.
- Click Authorize with Rakuten Advertising.
- Click Submit.
- Click Save.
- Select the Rakuten Advertising data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Rakuten Advertising data source, and click Connect.
