This guide will walk you through how to authenticate or reauthenticate Affluent with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Affluent, you need an API key and an API URL.
- Contact your Affluent admin to get your API key.
- For the API URL, replace {server} in this URL with the name of your Affluent server: https://{server}-api.affluent.io/
- Find your Affluent server name in your Affluent URL.
- For example, if your Affluent URL was accountname.affluent.io/, your server name would be accountname.
- Don't forget to include / at the end of your API URL.
Learn more about API keys and API URLs in Affluent's documentation.
Supermetrics offers the Performance report type, which fetches detailed performance data for affiliate marketing campaigns.
For Excel users
- Click Create query.
- Under Data source, select Affluent.
- Enter your credentials and click Log in.
- Click Allow.
- Under Select accounts, select the accounts.
- Navigate to Affluent and click Try.
- Click Authorize.
- If you’re authenticating the data source for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
- Select your accounts.
- Click Connecton the top right-hand side.
- Click the edit icon next to Affluent in the Data Studio sidebar.
- Scroll down to Parameters.
Before you can authenticate Affluent in Excel, you need to install the Supermetrics add-in.
- Enter your email address and password and click Log in.
- BigQuery
- Data warehouses and cloud storage (Amazon S, Google Cloud Storage, Snowflake, Azure Storage, or Azure Synapse)
- The Supermetrics API
Reauthenticate Affluent
