Follow these steps to connect your Sendinblue data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Sendinblue to Supermetrics, you need an API key. Remember to keep this safe once you have it.
Create an API key
- Log in to Sendinblue.
- Click your account's name in the top right corner.
- Select SMTP & API.
- Click Create a new API key.
- Enter a name for your API key (for example, “Supermetrics”).
- Click Generate.
- Copy the API key from the list under "Your API keys".
Learn more about API keys in Sendinblue's documentation.
- Email campaigns: Pulls the most popular performance metrics for email campaigns
- Under Data source, select Sendinblue.
- Enter your API key.
- Navigate to Sendinblue and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Sendinblue requires authorization to connect to data").
- Select the query type and the accounts you'd like to include in your reports, and click Next.
- Click + Create transfer.
- Select the Sendinlue data source.
- Accept the agreement.
- Click Authorize with Sendinblue.
- Click Submit.
- Click Save.
- Click Create new.
- Select the Sendinblue data source, and click OK.
- Click Create transfer.
- Click Select data source.
- Select the Sendinblue data source.
- Fill in the query details.
- Hover over the Sendinblue data source, and click Connect.
