LiveIntent: Authentication guide
This guide will walk you through how to authenticate or reauthenticate LiveIntent with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to LiveIntent, you need:
  • LiveIntent uses OAuth 2.0 to connect users to its reporting API.
  • Contact your LiveIntent admin set OAuth 2.0 up for your account.
For Excel users
Google Sheets Data Studio Excel Data integrations
  3. Click Create query.
  4. Under Data source, select LiveIntent.
  5. Click Start.
  6. Enter your credentials and click Log in.
  7. Click Allow.
  8. Under Select accounts, select the accounts.
  • If you encounter an authentication error such as “authentication failed”, “you need to reauthenticate” or similar, see this guide.
