AppsFlyer connection guide
Follow these steps to connect your AppsFlyer data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to AppsFlyer, you need:
  • Account admin access
  • API token (V2.0)
Retrieve your API tokens
  1. Log in to AppsFlyer.
  2. Click the email address in the top right corner to open the user menu drop-down.
  3. Click Security center.
  4. Under AppsFlyer API tokens, select Manage your AppsFlyer API tokens.
  5. Copy the V2.0 API token.
Learn more about retrieving and managing your tokens in AppsFlyer's documentation.
Supermetrics supports 2 report types to fetch performance data on how different marketing channels and user acquisition sources perform.
  • Aggregated performance (Pull API) report: Get basic aggregated performance data for your mobile apps. This report is available for all AppsFlyer users.
  • Aggregated performance (Master API) report: Fetch more granular data with less restrictive rate limits, including ad group, ad, and keyword splits. The Master API requires a separate subscription; please contact AppsFlyer to gain access. Learn more about the Master API in AppsFlyer's documentation.
  • Event data export: Fetch raw event level data, each row is one event logged in AppsFlyer.
    The raw data from the Event data export query type (any fields that begin with raw_data_) is only available in data warehouse destinations and the Supermetrics API. You also need an Enterprise AppsFlyer subscription with raw data API enabled.
  3. Click Create new query.
  4. Under Data source, select AppsFlyer.
  6. Enter your API token.
  7. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Click Start.
  2. Navigate to AppsFlyer and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "AppsFlyer requires authorization to connect to data").
  7. Enter your API token.
  8. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  9. Click Start.
  10. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select AppsFlyer.
  5. Enter your API token.
  6. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  7. Click Start.
Data warehouse
  3. Click + Create transfer.
  4. Select the AppsFlyer data source.
  7. Accept the agreement.
  8. Click Authorize with AppsFlyer.
  9. Enter your API token.
  10. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  11. Click Start.
  13. Click Submit.
  14. Click Save.
  2. In the sidebar, go to StorageTransfers.
  3. Click New transfer. If you haven't created any transfers yet, click Schedule first transfer.
  4. Select the AppsFlyer data source, and click OK.
  9. Click Start.
  11. Click Create transfer.
Power BI
  2. In the sidebar, go to DestinationsPower BI.
  3. Click Create or edit queries.
  4. Click Select a data source.
  5. Select the AppsFlyer data source.
  8. Click Start.
  9. Fill in the query details.
  10. Click Run query to test your query.
The Supermetrics API
  2. In the sidebar, click API.
  4. Click Select data source.
  8. Click Start.
Supermetrics Hub
  2. In the sidebar, click Data sources.
  4. Hover over the AppsFlyer data source, and click Connect.
  7. Click Start.
