Follow these steps to connect your Adtraction data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Adtraction, you need an Adtraction API token. These are also referred to as API keys.
To generate this token:
- Log in to Adtraction.
- Navigate to Account → Settings.
- Select API from the navigation menu.
- Copy the API token. Remember to keep it safe.
Supermetrics supports 2 Adtraction query types:
- Advertiser
- Affiliate accounts
If you're logged with an API token belonging to an advertiser account, you can only use the report types intended for advertiser users. The same applies to affiliate accounts.
- Under Data source, select Adtraction.
- Enter your API key.
- Select a query type, status, and other options.
- Navigate to Adtraction and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Adtraction requires authorization to connect to data").
- Select the status and other options, depending on the selected query type.
- Click + Create transfer.
- Select the Adtraction data source.
- Accept the agreement.
- Click Authorize with Adtraction.
- Click Submit.
- Click Save.
- Select the Adtraction data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Adtraction data source, and click Connect.
