This guide will walk you through how to authenticate or reauthenticate Spotify Ads with Google Sheets, Data Studio, and Excel.
- Under Data source, select Spotify Ads.
- Enter the credentials you use to log into Spotify, or authenticate with a Facebook, Apple, or Google account.
- Click Log in.
- Click Agree.
When you're ready, learn how to create your first Supermetrics query with Spotify Ads.
- Navigate to Spotify Ads and click Try.
- Click Authorize. If you're authenticating the data source for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
- Click Log in.
- Click Agree.
- Select the query type and click Next.
Connections
- Click Log in.
- Click Agree.
- BigQuery
- The Supermetrics API
Reauthenticate
