This guide will walk you through how to authenticate or reauthenticate Onisend with Google Sheets, Data Studio, and Excel.
To connect Supermetrics to Omnisend, you need:
- An e-commerce store or website connected to your Omnisend account.
- An Omnisend API key. Learn how to generate this key in Omnisend's documentation.
- Under Data source, select Omnisend.
- Enter your Account name and API key and click Start.
When you're ready, learn how to create your first Supermetrics query with Omnisend.
- Navigate to Omnisend and click Try.
- Click Authorize.
- Click Authorize.
- Scroll down to Parameters.
Connections
- Under Select accounts, select the accounts.
- BigQuery
- The Supermetrics API
Reauthenticate
