Follow these steps to connect your Awin data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API.
To connect Supermetrics to Awin, you need Awin API credentials.
- Go to the Awin API credentials page.
- Enter your Awin password and click Show my API token.
- Copy the API token.
Learn more about how to create these credentials in the Awin wiki.
Supermetrics supports 3 Awin query types.
- Publisher report: Get aggregate performance metrics, like impressions and transactions, per publisher.
- Creative report: Fetch aggregate performance metrics, like impressions and transactions, per creative used.
- Transactions report: Pull all individual transactions to check their status and commissions paid.
- Under Data source, select Awin.
- Enter your API key.
- Select your accounts.
- Navigate to Report configuration and select a query type and filters.
- Navigate to Awin and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Awin requires authorization to connect to data").
- Select your accounts and a query type, and click Next.
- Click + Create transfer.
- Select the Awin data source.
- Accept the agreement.
- Click Authorize with Awin.
- Click Submit.
- Click Save.
- Select the Awin data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Awin data source, and click Connect.
