Use this guide to connect Reddit Ads to Supermetrics.
For Excel users
- Click Create query.
- Under Data source, select Reddit Ads.
- Enter your account details, and click Sign in.
- Click Allow.
- Select your query type and target URL.
- Navigate to Reddit Ads and click Try.
- Click Authorize.
- If you're connecting Reddit Ads for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
- Click Allow.
- Click Allow.
