Availability
We're working on a new version of our Reddit Ads data source connector. The new data source connector will be available first in Google Sheets and Excel.
We'll release the new Reddit Ads connector for Looker Studio, the Supermetrics API, and data warehouse destinations soon. If you've been using our old Reddit Ads (Legacy) data source connector in a data warehouse destination, you can keep using it until the new connector is released.
Follow these steps to connect your Reddit Ads data to Supermetrics and use your data in Google Sheets.
You need to ask your Reddit Ads contact person to enable the Reddit Ads API for you.
- Main report: Fetch performance, conversions, and video metrics from your Reddit Ads campaigns.
- Under Data source, select Reddit Ads.
- Log in to your Reddit account.
- Click Allow to allow the Supermetrics app to access your profile data.
