Salesforce Marketing Cloud connection guide
Follow these steps to connect your Salesforce Marketing Cloud data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, and data warehouses, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect, you need:
  • A Pro, Corporate, or Enterprise edition Salesforce Marketing Cloud account
  • A Salesforce Marketing Cloud account with either the Administrator or Marketing Cloud Administrator user role (note that you'll only need to log in as this user the first time you connect — you can use other accounts later)
  • A client ID, client secret, and subdomain. Make sure to keep these safe and secure once you have them.
To get the client ID, client secret, and subdomain, you need to create a package and add the API integration component to it.
Step 1: Create a package
  1. Log in to Salesforce Marketing Cloud with a Marketing Cloud Administrator or Administrator account.
  2. Enter your username and password, and click Log in.
  3. Click your user account icon in the top-right corner.
  4. Click Setup.
  5. Navigate to "Apps" in the right-side menu. Select Installed packages.
  6. Click New on the top right corner.
  7. Give the package a name. The description field can be left empty.
  8. Click Save to confirm.
Step 2: Add the API integration component
  1. Go to Installed packages and find the package you created in Step 1. Click it to open the configuration view.
  2. Click Add component.
  3. Select "API Integration" as the component type. Click Next.
  4. Select "Server-to-Server" as the integration type. Click Next.
  5. Add Read permission to the following properties:
    • Email
    • Push
    • SMS
    • Documents & Images
    • Journeys
    • List and Subscribers
    • Tracking Events
    • Campaign
    • Accounts
    • Users
  6. Click Save to confirm.
Step 3: Retrieve the client ID, client secret, and subdomain for the installed package
When you view the installed package in Salesforce, you'll see the client ID and client secret under the API Integration heading.
Find the subdomain in the "Authentication Base URL" section, just below the client ID and secret. Only select the text between https:// and .auth.marketingcloudapis.com/
  3. Click Create new query.
  4. Under Data source, select Salesforce Marketing Cloud.
  5. Enter your client ID, client secret, and subdomain.
  7. Click Start.
  8. Select the accounts you'd like to include in your reports.
  2. Navigate to Salesforce Marketing Cloud and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Salesforce Marketing Cloud requires authorization to connect to data").
  6. Enter your client ID, client secret, and subdomain.
  8. Click Start.
  9. Select the accounts you'd like to include in your reports.
  10. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Salesforce Marketing Cloud.
  4. Enter your client ID, client secret, and subdomain.
  6. Click Start.
  7. Select the accounts you'd like to include in your reports.
Data warehouse
  3. Click + Create transfer.
  4. Select the Salesforce Marketing Cloud data source.
  7. Accept the agreement.
  8. Click Authorize with Salesforce Marketing Cloud.
  9. Enter your client ID, client secret, and subdomain.
  10. Click Start.
  11. Select the accounts you'd like to include in your reporting and define the transfer settings.
  12. Click Submit.
  13. Click Save.
  3. Click Create new.
  4. Select the Salesforce Marketing Cloud data source, and click OK.
  7. Enter your client ID, client secret, and subdomain.
  8. Click Start.
  9. In the transfer setup view, select the accounts you'd like to include in your reporting.
  10. Click Create transfer.
The Supermetrics API
  4. Click Select data source.
  5. Select the Salesforce Marketing Cloud data source.
  7. Click Start.
  8. Fill in the query details. See detailed instructions on how to set up a Supermetrics API query in Query Manager.
  9. Click Run to test your query.
Supermetrics Hub
  4. Hover over the Salesforce Marketing Cloud data source, and click Connect.
  6. Click Start.
