Follow this guide to connect your Salesforce Marketing Cloud data to Supermetrics. The process has several steps — follow the instructions carefully, and let us know if you need any help.
To connect, you need:
- A Pro, Corporate, or Enterprise edition Salesforce Marketing Cloud account
- A Salesforce Marketing Cloud account with either the Administrator or Marketing Cloud Administrator user role (note that you'll only need to log in as this user the first time you connect — you can use other accounts later)
- A client ID, client secret, and subdomain. Make sure to keep these safe and secure once you have them.
Generate a client ID, client secret, and subdomain
- Log in to Salesforce Marketing Cloud with a Marketing Cloud Administrator or Administrator account.
- Enter your username and password, and click Log in.
- Click your user account icon in the top-right corner.
- Click Setup.
- Navigate to "Apps" in the right-side menu. Select Installed packages.
- Click New on the top right corner.
- Give the package a name. The description field can be left empty.
- Click Save to confirm.
- Go to Installed packages and find the package you created in Step 1. Click it to open the configuration view.
- Click Add component.
- Select "API Integration" as the component type. Click Next.
- Select "Server-to-Server" as the integration type. Click Next.
- Add Read permission to the following properties:
- Push
- SMS
- Documents & Images
- Journeys
- List and Subscribers
- Tracking Events
- Campaign
- Accounts
- Users
For Excel users
- Under Data source, select Salesforce Marketing Cloud.
- Enter your client ID, client secret, and subdomain.
- Select the accounts you'd like to include in your reports.
- Navigate to Salesforce Marketing Cloud and click Try.
- Click Authorize.
- If you're connecting Salesforce Marketing Cloud for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
