Follow these steps to connect your The Trade Desk data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to The Trade Desk, you need the Partner-level reporting user role and access to partner cost metrics. There might be fees associated with API access that you'll pay to The Trade Desk.
Note that you'll need to sign a form with The Trade Desk to grant access to your data. Like any third-party supplier, Supermetrics isn't involved with the creation of this document.
- Under Data source, select The Trade Desk.
- Enter your email address and password, and time zone.
- Navigate to The Trade Desk and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "The Trade Desk requires authorization to connect to data").
- Click + Create transfer.
- Select the The Trade Desk data source.
- Accept the agreement.
- Click Authorize with The Trade Desk.
- Click Submit.
- Click Save.
- Click Create new.
- Select the The Trade Desk data source, and click OK.
- Click Create transfer.
- Click Select data source.
- Fill in the query details.
- Hover over the The Trade Desk data source, and click Connect.
