This guide will walk you through how to authenticate or reauthenticate Klaviyo in Supermetrics for Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Klaviyo, you need a Klaviyo account with an Admin, Owner, or Manager user role level. Learn more about user management and privileges in Klaviyo's documentation
You'll also need to generate an API key before you can connect. Follow Klaviyo's instructions to generate your API key.
- Under Data source, select Klaviyo.
- Enter your API key.
- Select the accounts you'd like to use in your reporting.
When you're ready, learn how to create your first Supermetrics query with Klaviyo.
- Navigate to Klaviyo and click Try.
- Click Authorize.
- Click Authorize.
- Enter your API key and click Start.
- Scroll down to Parameters.
Connections
- BigQuery
- The Supermetrics API
