Klaviyo connection guide
Follow these steps to connect your Klaviyo data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect to Supermetrics, your Klaviyo account needs one of these user roles:
  • Admin
  • Owner
  • Manager
Learn more about user management and privileges in Klaviyo's documentation.
You'll also need to generate a private API key with a read-only scope, which you'll then use to connect your data. Follow these instructions to generate your private API key. Remember to keep the API key safe.
  3. Click Create new query.
  4. Under Data source, select Klaviyo.
  5. Enter your API key.
  6. Give your account a name. The name can be anything — its purpose is for you to recognize the account later in case you have multiple accounts.
  8. Click Start.
  9. Select the accounts you'd like to use in your reporting.
  2. Navigate to Klaviyo and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Klaviyo requires authorization to connect to data").
  7. Click Start.
  8. Enter your API key.
  9. Give your account a name. The name can be anything — its purpose is for you to recognize the account later in case you have multiple accounts.
  10. Click Start.
  11. Select the accounts you'd like to use in your reporting.
  12. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  13. In the pane's top right, click Connect.
  14. Click Create report.
  15. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Klaviyo.
  7. Click Start.
  8. Select the accounts you'd like to use in your reporting.
Data warehouse
  3. Click + Create transfer.
  4. Select the Klaviyo data source.
  7. Accept the agreement.
  8. Click Authorize with Klaviyo.
  9. Enter your API key.
  10. Give your account a name. The name can be anything — its purpose is for you to recognize the account later in case you have multiple accounts.
  11. Click Start.
  13. Click Submit.
  14. Click Save.
  2. In the sidebar, go to StorageTransfers.
  3. Click New transfer. If you haven't created any transfers yet, click Schedule first transfer
  4. Select the Klaviyo data source, and click OK.
  7. Enter your API key.
  8. Give your account a name. The name can be anything — its purpose is for you to recognize the account later in case you have multiple accounts.
  9. Click Start.
  11. Click Create transfer.
Power BI
  2. In the sidebar, go to DestinationsPower BI.
  3. Click Create or edit queries.
  4. Click Select a data source.
  5. Select the Klaviyo data source.
  6. Enter your API key.
  7. Give your account a name. The name can be anything — its purpose is for you to recognize the account later in case you have multiple accounts.
  8. Click Start.
  9. Fill in the query details.
  10. Click Run query to test your query.
The Supermetrics API
  2. In the sidebar, click API.
  4. Click Select data source.
  8. Click Start.
Supermetrics Hub
  2. In the sidebar, click Data sources.
  4. Hover over the Klaviyo data source, and click Connect.
  7. Click Start.
