This guide will walk you through how to authenticate or reauthenticate StackAdapt in Supermetrics for Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to StackAdapt, you need an API key. Contact your StackAdapt account manager to create a key.
- Under Data source, select StackAdapt.
- Enter your API key and click Start.
- Select the accounts you'd like to use in your reporting.
- Navigate to StackAdapt and click Try.
- Click Authorize.
- Click Authorize.
Connections
- Under Data source, select the data source.
- BigQuery
- The Supermetrics API
