StackAdapt connection guide
Follow these steps to add your StackAdapt data to the reports you create with Supermetrics.
You'll need an API key to give Supermetrics permission to pull your data. Contact your StackAdapt account manager to create this key.
For Excel users
Google Sheets Data StudioExcel
  3. Click Create new query.
  4. Under Data source, select StackAdapt.
  5. Click Start.
  6. Enter your API key, and click Start.
  7. Select the accounts you'd like to use in your reporting.
