Follow these steps to connect your CallRail data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to CallRail, you need:
- An API key. Follow these instructions in CallRail’s documentation to create your key.
- The Admin, Manager, or Reporting user role level for each business account. Learn more about user roles and user management.
- Calls
- Returns data on calls and leads acquired through calls. Find metrics like the number of calls, answer rate, call duration, lead amount, and lead value.
- Gathers data about call insights by splitting the data by time, call source, number, or agent. This can help with resource planning and identifying the best-performing agents.
- Gathers data on a specific call and fetches direct links to recordings.
- Form submissions
- Returns data on form submissions and leads acquired through forms. Find metrics like the number of form submissions, lead amount, and lead value.
- Gathers lead insights by splitting the data by time or by source. You can also fetch all form submission data to dig into specific answers.
- Under Data source, select CallRail.
- Enter your API key.
- Select a query type to use in your report.
- Navigate to CallRail and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "CallRail requires authorization to connect to data").
- Click + Create transfer.
- Select the CallRail data source.
- Accept the agreement.
- Click Authorize with CallRail.
- Click Submit.
- Click Save.
- Select the CallRail data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the CallRail data source, and click Connect.
