Follow these steps to connect your Yahoo DSP data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Yahoo DSP, you need API access, including a client ID and client secret. Read Yahoo DSP's documentation to learn how to get access.
- Under Data source, select Yahoo DSP.
- Enter your client ID and client secret.
- Navigate to Yahoo DSP and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Yahoo DSP requires authorization to connect to data").
- Click + Create transfer.
- Select the Yahoo DSP data source.
- Accept the agreement.
- Click Authorize with Yahoo DSP.
- Click Submit.
- Click Save.
- Select the Yahoo DSP data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Yahoo DSP data source, and click Connect.
