This guide will walk you through how to authenticate or reauthenticate Semrush Projects in Supermetrics with Google Sheets, Data Studio, and Excel.
To connect Supermetrics to Semrush Projects, you need an API account with Semrush and a Semrush subscription for API request units. Learn more about Semrush accounts and API request units.
- Open a new Google Sheets file
- Click Add-ons → Supermetrics → Launch to open the sidebar.
- Under Data source, select Semrush Projects.
- Enter your API key and click Start.
- Select the project.
- Select the query type.
- Navigate to Semrush Projects and click Try.
- Click Authorize.
- If you're authenticating the data source for the first time, log in to Supermetrics with the Google Account you use in Data Studio. Click Allow.
- Click Authorize.
- Select the query type and click Next.
- Depending on the query type you choose, there will be additional filters to select. The Tracked URL field is required.
Connections
Before you can authenticate Semrush Projects in Excel, you need to install the Supermetrics add-on.
- Click Data → Show Supermetrics
