This guide will walk you through how to authenticate or reauthenticate Semrush Analytics in Supermetrics with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Semrush Analytics, you need an API account with Semrush and a Semrush subscription for API request units. Learn more about Semrush accounts and API request units.
Semrush Analytics supports 5 main types of queries — Domain, Keyword, URLs, Display Ads, and Backlinks — for a total of 35 different query types.
- The data source uses the same structure as the API reports with the same names, so you can use the Semrush Analytics API documentation to find out what specific reports and fields are available.
- Click Add-ons → Supermetrics → Launch to open the sidebar.
- Under Data source, select Semrush Analytics.
- Enter your email and password, and click Log in.
- Click Approve.
- Under Query type, select the query type.
- Enter one or more domains. Separate them with commas.
- Navigate to Semrush Analytics and click Try.
- Click Authorize.
- Click Authorize.
- Click Approve.
- Select the query type, and click Next.
When you're ready, learn how to create your first Supermetrics query with Semrush Analytics.
- Scroll down to Parameters.
Connections
Choose to make this connection shared or private.
Click Approve.
- As an additional filter, you can select the Display date.
- BigQuery
- The Supermetrics API
