Follow these steps to connect your Semrush Analytics data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Semrush Analytics, you need an API account and a Semrush subscription for API request units. Learn more about Semrush accounts and API request units.
Semrush Analytics supports 5 main types of queries — Domain, Keyword, URLs, Display Ads, and Backlinks — for a total of 35 different query types.
Our connector uses the same structure as the API reports with the same names, so you can use the Semrush Analytics API documentation to explore the full range of reports and fields.
See our Semrush Analytics report building guide for more information about query types for this connector.
- Under Data source, select Semrush Analytics.
- Enter your Semrush Analytics email and password, and click Log in.
- Click Approve.
- Select a query type.
- Enter one or more domains, separating each one with a comma with no whitespace (,).
- Navigate to Semrush Analytics and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Semrush Analytics requires authorization to connect to data").
- Click Approve.
- Select a query type and click Next.
- Click Approve.
- Click + Create transfer.
- Select the Semrush Analytics data source.
- Accept the agreement.
- Click Authorize with Semrush Analytics.
- Click Approve.
- Select the domains you'd like to include in your reporting and define the transfer settings.
- Click Submit.
- Click Save.
- Select the Semrush Analytics data source, and click OK.
- Click Approve.
- In the transfer setup view, select the domains you'd like to include in your reporting.
- Click Create transfer.
- Click Select a data source.
- Click Approve.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Click Approve.
- Hover over the Semrush Analytics data source, and click Connect.
- Click Approve.
