Ahrefs: Authentication guide
This guide will walk you through how to authenticate or reauthenticate Ahrefs with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Ahrefs, you need:
Multiple user accounts
It's not possible to add multiple user accounts in the same login for Ahrefs. To log in with a different user account, you need to log out from all other Ahrefs accounts in Supermetrics.
Target URL
For the field "target URL" we support HTTP, HTTPS, and WWW.
For Excel users
  3. Click Create query
  4. Under Data source, select Ahrefs.
  5. Click Start.
  6. Enter your email address and password, and click Sign in.
  7. Click Allow.
  8. Navigate to Report configuration.
  9. Under Query types, select the query type.
  10. Under Target URL, insert the target URL.
When you're ready, learn how to create your first Supermetrics query with Ahrefs.
