This guide will walk you through how to authenticate or reauthenticate Outbrain Amplify with Google Sheets, Data Studio, and Microsoft Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Outbrain Amplify, you need:
- API access from Outbrain. You won't be able to use the connector without this.
- Contact your account manager at Outbrain to allowlist API access for your account. Alternatively, fill out this form to request API access from Outbrain.
- Once Outbrain has approved your API access, log into the Supermetrics connector with the approved username and password.
- Under Data source, select Outbrain Amplify.
- Enter your username or email and password, and click Start.
- Select the accounts you'd like to use in your reporting.
When you're ready, learn how to create your first Supermetrics query with Outbrain Amplify.
- Navigate to Outbrain Amplify and click Try.
- Click Authorize.
- Click Authorize.
- Enter your credentials and click Start.
- Scroll down to Parameters.
Connections
- BigQuery
- The Supermetrics API
Reauthenticate
