Follow these steps to connect Outbrain Amplify to Supermetrics, and start pulling its data into your reports.
To connect Supermetrics to Outbrain Amplify, you need API access from Outbrain.
- Contact your account manager at Outbrain to allowlist API access for your account. Alternatively, fill out this form to request API access from Outbrain.
- Once Outbrain has approved your API access, follow the steps below to complete your connection.
For Excel users
- Under Data source, select Outbrain Amplify.
- Enter your username and password, and click Start.
- Select the accounts you'd like to use in your reporting.
- Navigate to Outbrain Amplify and click Try.
- Click Authorize.
- If you're connecting Outbrain Amplify for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
