This guide gives instructions on how to authenticate YouTube with Google Sheets, Data Studio, and Microsoft Excel.
To connect Supermetrics to a YouTube brand account, you need Content manager access. Learn how to find out which type of account you're using in Google's documentation.
For all types of accounts and channels, the account logging in needs to be the channel's owner.
- Under Data source, select YouTube.
- Log in with a Google Account.
- Click Allow.
- Select accounts or channels to include in your reporting.
- Open the Supermetrics data source gallery
- Navigate to YouTube and click Try.
- Click Authorize to authorize.
- Click Authorize.
- Click Allow.
- To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
Connections
Before you can authenticate Semrush Analytics in Excel, you need to install the Supermetrics add-in.
- Click Data → Show Supermetrics
- Click Allow.
- Select channels and videos to include in your reporting.
- BigQuery
- The Supermetrics API
If an account is missing from your available accounts in Supermetrics (including channels and videos), follow these steps:
- Create a new Google Account.
- Log into YouTube Creator Studio with your original Google Account.
- Navigate to Settings and then Permissions in the left-side menu.
- Click Invite in the top right.
- Add the new Google Account as the new user.
- Create the new user as a Manager (if you're using a brand channel, Owner would also work). Click Invite.
- Open the invitation email while logged in as the new user. Click Visit the sign-up page to accept the invitation.
- Select Use existing Google Account.
- Go back to the Supermetrics sidebar, and click add a new user.
