This guide will walk you through how to authenticate or reauthenticate Quora Ads with Google Sheets, Data Studio, andExcel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Quora Ads, you need a Quora account with the Admin user role level. See Quora’s documentation to learn how to grant access to a Quora account.
- Under Data source, select Quora Ads.
- Enter your email address and password and click Log in.
- Click Accept.
- Navigate to Quora Ads and click Try.
- Click Authorize.
- Click Authorize.
- Click Accept.
- Select the accounts you'd like to include in your report.
Connections
- Under Data source, select the data source.
- Click Accept.
- BigQuery
- The Supermetrics API
