Use this guide to connect Pinterest Ads or Pinterest Organic to Supermetrics.
If you need to connect either data source to one of our data warehouse or cloud storage destinations, explore our prerequisite and filling guides.
Your Pinterest accounts need specific permissions before they can connect to Supermetrics.
- To connect to Pinterest Ads, you need a Pinterest user account with at least Admin or Campaign access to an ad account.
- To connect to Pinterest Organic, you need to log in with the profile's Owner account. Note that Supermetrics can only pull data from business profiles.
For Excel users
- Click Create query.
- Under Data source, select Pinterest Ads or Pinterest Organic.
- Enter your email address and password, and click Log in.
- Click Give access.
- For Pinterest Organic, navigate to Report configuration and select a query type.
- Navigate to Pinterest Ads or Pinterest Organic and click Try.
- Click Authorize.
- If you're connecting Pinterest Ads or Pinterest Organic for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
