Follow these steps to connect your Pinterest Ads data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect to Pinterest Ads, you need a Pinterest user account with at least Admin or Campaign access to an ad account.
- Click Create query.
- Under Data source, select Pinterest Ads.
- Enter your email address and password, and click Log in.
- Click Give access.
- Navigate to Pinterest Ads and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Pinterest Ads requires authorization to connect to data").
- Enter your Pinterest email address and password, and click Log in.
- Click + Create transfer.
- Select the Pinterest Ads data source.
- Accept the agreement.
- Click Authorize with Pinterest Ads.
- Click Submit.
- Click Save.
- Click Create new.
- Select the Pinterest ADs data source, and click OK.
- Click Create transfer.
- Click Select data source.
- Fill in the query details.
- Hover over the Pinterest Ads data source, and click Connect.
